Error afer trasnfer Database
  • elwgr
    • Jun 2023
    i have run a Zabbix 6.0.0, its working fine - but only without https.
    Now i have installed a completley new server with Zabbix 6.4.
    First its runnig fine, installed all the certificates,.... done.
    The i have transfer the mySQL database from the old server to the new, and now its writing
    "The Zabbix database version does not match current requirements. Your database version: 5050072. Required version: 6040000. Please contact your system administrator."
    in the log is writing this:
    what i can do it to make it RUN the new server?
    Thanks!
  • PeterZielony
    • Nov 2022
    • 146
    Upgrade database version. You are trying to run database from 6.0.0 on 6.4.
    You need to find info how to upgrade from 6 to 6.4.. probably zabbix website
    Hiring in the UK? Drop a message
    • elwgr
      • Jun 2023
      i cant find the correctly comand to upgrade the DB.
      i find all the upgrade comands for upgrade the Zabbix-Server.... But i have a new Zabbix installation and want migrate the old DB.
        So you created a completely new DB (for v6.4.3), and managed to import data from old DB into it (from 5.0.x)?
        What you should actually do, is not create DB schema for 6.4.3 but for your old version. and import your old data into that before you ever start up your server... In that case there is no unknown columns for upgrade scripts in DB and your upgrade procedures should succeed. Currently they start, but fail...
