Limiting graphs to only graph prototype
  • tprice9
    • Jun 2023
    Hi all,
    I am looking for some help to remove graphs we do not need, Zabbix version is 6.4.1.
    Currently we have a discovery rule with item prototypes for BytesIn and BytesOut, that are tied to a graph prototype that displays network traffic. Currently graphs are generated for each item prototype and then also the graph prototype, is there a way to only have the graph prototype generated? We do not want to see the traffic isolated to in or out just together in the prototype. When filtering by "Host graphs" on a host we get only the graph prototype, and would like to eliminate these extra graphs so it is the same when looking at "All graphs".
    Above is the item prototypes
    Above is the graph prototype​​
    Graphing of single item data is out-of-the-box option. There is no separate "graph" created for each item. there is just an option to display it ad-hoc, from latest data page... Your pics also do not show any additional graph than the "combined" one...
    Or I just missed the real question..
    • tprice9
      • Jun 2023
      Thanks for your response, see the three graphs below. All 3 are generated from the discovery rule, can I limit the graphs to just the prototype?
      Above is looking at the graphs page of a host, I can only see the graph generated that is the prototype, but when I look at the host graphs there is the extra item graphs.​​
        As you template says "1 graph prototype" then those others come from other place...Anything in template directly?
