Disable alert actions if Zabbix ISP is down
  • info@davidstein.cz
    • Jun 2023
    Hello, it is possible to disable the alert actions if the Zabbix server ISP is down? We are monitoring about 100 devices and if the internet connection on our server fails. The Zabbix detects 100x "Zabbix agent is not available" and tries to send 100 emails.
    What I try:
    - Search forum
    - check the email correlation
    - check the trigger actions conditions
    - read the documentation
    - create the new ICMP ping check on google.com so now I got the trigger "ICMP Ping" but I do not know how to "use it"
    - I tried to edit the action triggers. I wanted to add the ICMP Ping as a condition but I was able just to filter out just the actions that are triggered by the ICMP Ping. But I need to do something like IF ISP_Internet.ICMP Ping is UP(1) THEN send an email ELSE do not send an email.
    Could you please somebody help? Thank you in advance
