Value of item into SQL on anather item
  • keminc
    • Sep 2020
    Hi everyone!
    Please try to solve a problem with me:
    I have item with date and i need to use this date in another [Database monitor] item into SQL, i try this construction but it isn’t work:
    SELECT {Monitoring:balance.date.last()} as dt from dual;
    So, how I can resolve this case and use value of one item into SQL of another?​
  • PeterZielony
    • Nov 2022
    • 146
    That's not the correct syntax
    last(/host/key,<#num<:time shift>>)
    ​Never done it this way as you describe but if it would work you would have to fix the syntax to find out
    Hiring in the UK? Drop a message
      You just cant use one items value as other items paramater(s)....
