Top Hosts - but for ports?
  • tdk1069
    • Jun 2023
    I have been asked if it is possible to get something akin to the Top hosts widget we have running to monitor vm cpu/memory etc. but for our core switch to monitor bandwidth.
    We currently use a Graph but it can get a bit muddled having all the ports in/out in the chart, It would be nice to be able to have just the top 5-10-x ports listed in something like top hosts.
    I tried to set one up and quickly realised that that will only show me the ports I select for that host on one line.
    That, or any one have any way to tidy up/ make the graphs much simpler to read at a glance, 96 ports with in/out traffic isn't easy to get at a glance.
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi
    The feature request https://support.zabbix.com/browse/ZBXNEXT-7535 is exactly about top hosts widget but on discovered entities. Looking forward to see this implemented soon.
