Hello, I can't set up monitoring on VCenter 5.5.
Zabbix server version 5.2.6 Ubuntu 18, I connect to Vcenter 5.5 Windows server 2008, via Zabbix proxy 5.2.6 CentOS 8.
Everything is set up correctly, I tried to connect through a proxy to the esxi host, Zabbix receives all the data.
A user was created on vcenter, login, password and url are correct, there are connections. In the settings of the Zabbix host, the message ssl error hangs, I tried to connect via curl to the hosts and vcenter, the connection goes through to the host, to the vcenter there is a certificate error. On vcenter in the system settings there is permission for any versions of ssl.
I found old topic, with similar a problem, but user doesn't write answer how he fixed error.
