'Unavailable by ICMP ping'
  • beka123
    • Jun 2023
    Zabbix server can ping a host, but the host shows as 'Unavailable by ICMP ping' in Zabbix. any suggestions?
  • PeterZielony
    • Nov 2022
    • 146
    did you set IPMIPOLLERS in zabbix configuration? it's required for ping from server/proxy.
    Also, ensure fping is installed (don't remember if it's installed by default).
    On top of it, you need to make sure that Zabbix server/proxy user under zabbix instance is installed have permission to run fping
    Hiring in the UK? Drop a message
    • beka123
      beka123 commented
      The polling worked before, and the host had connectivity issues. Now those issues are fixed, Zabbix can ping successfully from its OS, but Unavailable by ICMP ping is still triggered in dashboard/problems.
    • 4993
    IPMIPOLLERS are NOT required for pinging...
    • freiheit
      • Dec 2022
      • 11
      Did you mean ICMP pingers and the StartPingers setting on server/proxy?
      OP: make sure the server/proxy has pingers running. Set StartPingers to something >= 1. Make sure that FpingLocation points to a working copy of fping and use that fping to test pinging the host showing problems (for starters).
      • PeterZielony
        • Nov 2022
        • 146
        that's the one. I was writing from memory
        IPMI is different thing
