Monitor Esxi via Snmp : bad url
  • Chico008
    • Jun 2023
    • 13
    Hello
    I installed a Zabbix server (6.4) to monitor our infrastructure.
    this server is installed on a Linux server (Ubuntu server 22.04).
    for the moment not too much trouble, I was able to add network equipment, firewall, temperature sensor, inverter.
    I'm also starting to customize dashboards for my elements (notably the inverters) it's pretty cool.
    on the other hand, I would like to add our Esx to supervise them, but I have a problem.
    I want to monitor them via snmp.
    On the esx side the conf is done, and from my server which hosts zabbix (linux), I can snmpwalk my esx, I have the values ​​displayed.
    on the other hand, on the zabbix side, I added my esx, as an snmp agent with its ip/port, the community is good, and as a template I took vmware hypervisor.
    and there, nothing.
    in the data, I have an error: Url using bad/illegal format or missing.
    what did I miss?
    wrong template? another conf missed somewhere?​
    • 4993
    That template just does not use SNMP .. It is configured to work over API...
