Can we measure the length of cable with SNMP in Network switch?
  • vijayk
    • May 2023
    • 305
    I have Netgear Switch XS728T ProSAFE. I need to measure the cable length. Is it possible with SNMP?
    • 4997
    Does your netgear switch have built-in capability to do it? If yes, then maybe there is a MIB, what also carries options to poll it... But that is just a big maybe here...
    • Hamardaban
      • May 2019
      • 2714
      Some points to start:
      agent Cable Tester Status
      1.3.6.1.4.1.4526.10.1.4.1
      Status of the Virtual Cable Tester active(1) - cable testing is in progress. Set to this value to start the test. success(2) - A successful test was performed. Cannot be set. failure(3) - A failure was encountered during the test. Cannot be set. uninitialized(4) - No test has been performed yet. Cannot be set.​
      agent Cable Tester If Index
      1.3.6.1.4.1.4526.10.1.4.2
      Determines on which port to perform the cable test. Limited to copper based ports.​
      agent Cable Tester Cable Status
      1.3.6.1.4.1.4526.10.1.4.3
      Indicates the results of the Cable Test. normal(1) - The cable is working correctly. open(2) - The cable is disconnected or there is a faulty connector. short(3) - There is an electrical short in the cable. unknown(4) - No test has been performed yet, or a test is currently in progress.​
      and etc
      • vijayk
        • May 2023
        • 305
        Thanks for the clue, Let me try it.
