how to delete event from zabbix using api?
  • user1234
    • Jul 2022
    • 35
    Hi
    is it possible to delete event from zabbix by event id using API?
    didn't find any api for that...
  • Hamardaban
    • May 2019
    • 2714
    Delete - no. Close - rtfm
    object event.acknowledge(object/array parameters)
    This method allows to update events. The following update actions can be performed:
    • Close event. If event is already resolved, this action will be skipped.
