Zabbix TimeOut not being applied
  • CristianR
    • Apr 2023
    • 12
    Hello Zabbix Community,
    I changed the timeout value both on the zabbix_server.conf file and on the zabbix_agentd.conf file
    Timeout=10
    but it does not seems being applied, since the scripts that takes more than 3s to run will fail with the error:
    Timeout while executing a shell script
    Any idea how to solve this problem?
    Thank you.
    Cristian
  • Atsushi
    • Aug 2013
    • 2028
    Did you restart the daemon or service after changing the config file?
    • CristianR
      • Apr 2023
      • 12
      Thanks for your reply Atsushi, I did restart the service but no luck.
