Logging with different filenames / Timestamp in filename of log
  • FFB-Group
    • Jan 2023
    • 14
    Hey guys,
    so i want to monitor logs from our own applications. The filename contains a timestamp. What is the best way to solve that? I only found solutions where the filename is always the same.
    I thought about a script which checks for the newest filename but i don't really now how to implement scripts in zabbix.
    Here a screenshot of my tests so far, both of them work like this:
    Sadly wildcards won't work in zabbix...
    Would really appreciate some help.
  • Hamardaban
    • May 2019
    • 2714
    Try logrt item key
    logrt[file regexp,<regexp>,<encoding>,<maxlines>,<mode>,<outp ut>,<maxdelay>,<options>,<persistent dir>]
    Parameters:
    • file regexp - the absolute path to file and the file name described by a regular expression. Note that only the file name is a regular expression.
    • FFB-Group
      • Jan 2023
      • 14
      Thanks, that worked for me.
      • FFB-Group
        • Jan 2023
        • 14
        Do you also have an idea how to do a trigger for the item?
        I tried it like this but it wont work
        I want to create a trigger which creates a error message each time it finds a new [ERR] entry in the log file.
        Thank you
        (As u can see i get data from the host)
        • Hamardaban
          • May 2019
          • 2714
          Does your data contain the substring ERR?
          I understand that based on the expression for logrt should - but how really?
          And of course you know that the trigger will not work according to the old data? only at the moment of the arrival of a new value?
