Can not login to Zabbix web interface
  • ahmedabdulla
    • Jul 2023
    Good Morning Colleagues
    I hope you are doing well . I am trying to login to web interface of Zabbix but it failed with the below error:
Name:	Connection Refused.jpg
    From CLI , I issue the command "tail -f /var/log/zabbix/zabbix_server.log​" and below is the output . The error below is error number 111 which is different than most of errors i found in the forum.
    1339:20230704:030824.426 [Z3001] connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
    1339:20230704:030824.427 database is down: reconnecting in 10 seconds​
    So kindly advice.
    Best Regards
