Here, you can see difference between zabbix server (first column), first proxy (second column) and third one (third column). Is it possible that it is buffer on proxy?
LogFile=/var/log/zabbix/zabbix_server.log LogFileSize=0 DebugLevel=3 PidFile=/var/run/zabbix/zabbix_server.pid DBHost=xyz.xyz.com DBName=xyz DBUser=xyz DBPassword=xyz StartPollers=35 StartDiscoverers=0 SNMPTrapperFile=/var/log/snmptrap/snmptrap.log HousekeepingFrequency=0 CacheSize=1G StartDBSyncers=8 HistoryCacheSize=1G HistoryIndexCacheSize=64M TrendCacheSize=1G ValueCacheSize=1G Timeout=15 AlertScriptsPath=/usr/lib/zabbix/alertscripts ExternalScripts=/usr/lib/zabbix/externalscripts LogSlowQueries=3000
Server=xxx.xxx.xxx.xxx Hostname=xyz LogFile=/var/log/zabbix/zabbix_proxy.log LogFileSize=0 DebugLevel=3 PidFile=/var/run/zabbix/zabbix_proxy.pid DBHost=localhost DBName=xxx DBUser=xxx DBPassword=xxx DBSocket=/var/lib/mysql/mysql.sock ConfigFrequency=600 StartPollers=1000 StartPollersUnreachable=150 StartDiscoverers=16 SNMPTrapperFile=/var/log/snmptrap/snmptrap.log CacheSize=1G StartDBSyncers=24 HistoryCacheSize=512M HistoryIndexCacheSize=64M Timeout=30 UnreachableDelay=5 ExternalScripts=/usr/lib/zabbix/externalscripts LogSlowQueries=3000
