Zabbix 3.0.3 | Dashboard Filter Missing "Problem Display"
  • marguz
    • Jul 2016
    All,
    Just installed Zabbix 3.0.3 (Centos7 rpms) and it seems the only way to "hide" acknowledged alerts is via the Dashboard Filter and setting the Problem Display field. Well for me, the Problem Desplay field is missing.
    Was it moved else where? I checked the docs and the docs call it out located in the Dashboard Filter section.
    Is this a bug and should I fill out a bug tracker?
  • Atsushi
    • Aug 2013
    • 2028
    Please check your "Enable event acknowledges" setting at Administration -> General -> GUI.
    Default status is checked that setting.
    • marguz
      • Jul 2016
      Atsushi,
      That was it... I must have disabled it trying to hide the alerts and forgot about it when I came across the Dashboard Filter in the docs.
      Thanks!
