Creating a trigger if text string exists in value
  • mdub
    • Nov 2022
    I have created a custom template with the following item :
    eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip]
    Which gives out the following value :
    The Task Scheduler has completed the task "Sending data", instance "{de22c11d-4a46-42a1-bf63-4ee91bd9c3gc}", action "C:\sending_data.exe" with the return code 0.
    I'd like to create a trigger for when the string "with the return code 0" is not present in the latest value.
    So far here is what I have for the trigger :
    logsource(/windows_acd-groupe_active/eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip],#1,"with the return code 0.")=0
  • PeterZielony
    • Nov 2022
    • 146
    You can use fin() function which returns true if present. Simple add "not" before function and you are sorted
    not(find())
    https://www.zabbix.com/documentation...s/history#find
    Hiring in the UK? Drop a message
    • mdub
      • Nov 2022
      Thanks for the help !
      I managed to create this trigger :
      not(find(/windows_acd-groupe_active/eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip],#1,,""with the return code 0.""))
      Which seemed to work since it resolved the ongoing problem on the dashboard.
      However, as soon as the value got updated, the trigger created a new problem. The strange thing is that the new value is identifcal to the last one and contains the string ""with the return code 0."
      • PeterZielony
        • Nov 2022
        • 146
        you missed operator (i'd use iregexp but aswell you can use "like").
        • operator (must be double-quoted). Supported operators:
          eq - equal (default for integer, float)
          ne - not equal
          gt - greater
          ge - greater or equal
          lt - less
          le - less or equal
          like (default for string, text, log) - matches if contains the string given in pattern (case-sensitive)
          bitand - bitwise AND
          regexp - case-sensitive match of the regular expression given in pattern
          iregexp - case-insensitive match of the regular expression given in pattern
        • pattern - the required pattern (string arguments must be double-quoted); Perl Compatible Regular Expression (PCRE) regular expression if operator is regexp, iregexp.
          Also double quoted means " not ""
          try this:
          not(find(eventlog[/windows_acd-groupe_active/eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip]),#1,"iregexp","with the return code 0")
          but make sure your host is also included at the beginning (or not if its via template) find(/host/key,(sec|#num)<:time shift>,<operator>,<pattern>)
        • mdub
          • Nov 2022
          I get the following error when trying to update the trigger (via the template) :
          Invalid parameter "/1/expression": incorrect expression starting from "find(eventlog[/windows_acd-groupe_active/eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip]),#1,"iregexp","with the return code 0")".
          • yoni_tech
            • Jan 2024
            Sorry for popping up this thread.
            As the last reply suggested that the creator of this thread did not solve it - I decided to reply here and maybe it can help the creator or other users who will look for this issue.
            Zabbix 6.X (and maybe older versions as well) supports the Left and Right trigger functions.
            In your case, the Right function might be one of the paths to use, example for a query I would use if I were you:
            not (right(last(/windows_acd-groupe_active/eventlog[Microsoft-Windows-TaskScheduler/Operational,"\Sending data",,TaskScheduler,201,,skip],#1),23)="with the return code 0.")
            The above function will check if the provided last 23 characters ARE NOT identical to the provided string - if so, it will trigger an issue.
            Hope I was able to assist.​
              I think the host part is in wrong place...
              find (/host/key,<(sec|#num)<:time shift>>,<operator>,<pattern>)​
