Hi All
First for all, thanks for this great software.
I have an issue implementing the "Veeam Backup and Replication by HTTP" template.
I can access the infrastructure from a zabbix server running in a remote location. The infrastructure is accesibe through a Zabbix Proxy installed into a docker container.
Y complete the macros as a show.
{$VEEAM.API.URL}. = https://192.168.0.8:9419
{$VEEAM.PASSWORD}. = the admin veeam user
{$VEEAM.USER} = the password​
The error registered into the zabbix proxy logs and into zabbix server is:
I not have any clue to workaround this error.
Any help will be apreciated.
Regards
Victor
| 2023-07-14 14:01:39 | Login failed with status code 400: {"errorCode":"NotImplemented","message":"Unsupp ort ed RESTAPI version. The following versions are supported: v1.0-rev1.","resourceId":null}. |
Regards
Victor
