Zabbix 6.0.19 - Can't monitor more than 1 host per network
  • choiniere
    • Jul 2023
    Hi. I'm running an instance of Zabbix 6.0.19 on a Linode server. My hosts are Windows devices, my Zabbix server is Linux. In my home network, I have two devices which I would like to monitor. They each have Zabbix Agent 2 installed. One agent is configured to listen on port 10049, and the other is configured to listen on port 10050. Neither of them have ServerActive set in the configuration files. The hostnames and ports of each respective agent match with the configuration I have on the Zabbix server. Both port 10049 and 10050 are forwarded, with firewall rules in place to allow requests on these ports through.
    With only one agent actually running, Zabbix monitors the host perfectly. Once I start up the second agent on my second device, they both monitor well for a few minutes. After a few minutes, they both produce the error "Get value from agent failed: cannot connect to [[xxx.xxx.xxx.xxx]]:10049]: [4] Interrupted system call" and "Get value from agent failed: cannot connect to [[xxx.xxx.xxx.xxx]]:10050]: [4] Interrupted system call". If left like this, they will sporadically reconnect and send small amounts of information to the server before being dropped again quickly, repeatedly.
    I've pored over my configuration files. They both seem to work fine. Each agent works perfectly on their own; it's when I try running both at the same time that the Zabbix server seemingly fails to consistently maintain a connection. Trying to ping the hosts with telnet from the Zabbix server produces similar results; the pings fail when the Zabbix frontend shows the aforementioned errors, and the pings succeed when Zabbix shows the hosts as up. It seems to me that the Zabbix agents stop listening on their respective ports for a period of time. When restarting the Zabbix agent & running netstat in the command line, I see the agent is listening on the required port (10049 or 10050). However, at some point the agent appears to stop listening (and Zabbix then shows both hosts down). Once this happens, running netstat fails to show 10049 or 10050 being listened to, even though the zabbix_agent2.exe process is still showing up in Task Manager.
    Any ideas as to what could be going on here? My config files:
    First config:
    # This is a configuration file for Zabbix agent 2 (Windows)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: LogType
    #    Specifies where log messages are written to:
    #        file    - file specified with LogFile parameter
    #        console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    #    Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
     LogFile=c:\Program Files\Zabbix Agent 2\bin\zabbix_agent2.log
    ### Option: LogFileSize
    #    Maximum size of log file in MB.
    #    0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    ### Option: DebugLevel
    #    Specifies debug level:
    #    0 - basic information about starting and stopping of Zabbix processes
    #    1 - critical information
    #    2 - error information
    #    3 - warnings
    #    4 - for debugging (produces lots of information)
    #    5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    DebugLevel=4
    ### Option: SourceIP
    #    Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ##### Passive checks related
    ### Option: Server
    #    List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    #    Incoming connections will be accepted only from the hosts listed here.
    #    If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    #    and '::/0' will allow any IPv4 or IPv6 address.
    #    '0.0.0.0/0' can be used to allow any IPv4 address.
    #    Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=xx.xx.xx.xx
    ListenPort=10049
    ### Option: ListenPort
    #    Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    #    List of comma delimited IP addresses that the agent should listen on.
    #    First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StatusPort
    #    Agent will listen on this port for HTTP status requests.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # StatusPort=
    ##### Active checks related
    ### Option: ServerActive
    #    Zabbix server/proxy address or cluster configuration to get active checks from.
    #    Server/proxy address is IP address or DNS name and optional port separated by colon.
    #    Cluster configuration is one or more server addresses separated by semicolon.
    #    Multiple Zabbix servers/clusters and Zabbix proxies can be specified, separated by comma.
    #    More than one Zabbix proxy should not be specified from each Zabbix server/cluster.
    #    If Zabbix proxy is specified then Zabbix server/cluster for that proxy should not be specified.
    #    Multiple comma-delimited addresses can be provided to use several independent Zabbix servers in parallel. Spaces are allowed.
    #    If port is not specified, default port is used.
    #    IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    #    If port is not specified, square brackets for IPv6 addresses are optional.
    #    If this parameter is not specified, active checks are disabled.
    #    Example for Zabbix proxy:
    #        ServerActive=127.0.0.1:10051
    #    Example for multiple servers:
    #        ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    #    Example for high availability:
    #        ServerActive=zabbix.cluster.node1;zabbix.cluster.node2:20051;zabbix.cluster.node3
    #    Example for high availability with two clusters and one server:
    #        ServerActive=zabbix.cluster.node1;zabbix.cluster.node2:20051,zabbix.cluster2.node1;zabbix.cluster2.node2,zabbix.domain
    # Mandatory: no
    # Default:
    # ServerActive=
    ### Option: Hostname
    #    List of comma delimited unique, case sensitive hostnames.
    #    Required for active checks and must match hostnames as configured on the server.
    #    Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=NTRIPServer
    ### Option: HostnameItem
    #    Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    #    Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    #    Optional parameter that defines host metadata.
    #    Host metadata is used at host auto-registration process.
    #    An agent will issue an error and not start if the value is over limit of 255 characters.
    #    If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    #    Optional parameter that defines an item used for getting host metadata.
    #    During an auto-registration request an agent will log a warning message if
    #    the value returned by specified item is over limit of 255 characters.
    #    This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: HostInterface
    #    Optional parameter that defines host interface.
    #    Host interface is used at host auto-registration process.
    #    If not defined, value will be acquired from HostInterfaceItem.
    # Mandatory: no
    # Default:
    # HostInterface=
    ### Option: HostInterfaceItem
    #    Optional parameter that defines an item used for getting host interface.
    #    This option is only used when HostInterface is not defined.
    # Mandatory: no
    # Default:
    # HostInterfaceItem=
    ### Option: RefreshActiveChecks
    #    How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    #    Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    #    Maximum number of values in a memory buffer. The agent will send
    #    all collected data to Zabbix Server or Proxy if the buffer is full.
    #    Option is not valid if EnablePersistentBuffer=1
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: EnablePersistentBuffer
    #    Enable usage of local persistent storage for active items.
    #    0 - disabled, in-memory buffer is used (default); 1 - use persistent buffer
    # Mandatory: no
    # Range: 0-1
    # Default:
    # EnablePersistentBuffer=0
    ### Option: PersistentBufferPeriod
    #    Zabbix Agent2 will keep data for this time period in case of no
    #    connectivity with Zabbix server or proxy. Older data will be lost. Log data will be preserved.
    #    Option is valid if EnablePersistentBuffer=1
    # Mandatory: no
    # Range: 1m-365d
    # Default:
    # PersistentBufferPeriod=1h
    ### Option: PersistentBufferFile
    #    Full filename. Zabbix Agent2 will keep SQLite database in this file.
    # Mandatory: no
    # Default:
    # PersistentBufferFile=
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    #    Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    #    Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    #    Different Alias keys may reference the same item key.
    #    For example, to retrieve the ID of user 'zabbix':
    #    Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.:([0-9]+),,,,\1]
    #    Now shorthand key zabbix.userid may be used to retrieve data.
    #    Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    #    Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: Include
    #    You may include individual files or all files in a directory in the configuration file.
    #    Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=c:\zabbix\zabbix_agent2.userparams.conf
    # Include=c:\zabbix\zabbix_agent2.conf.d\
    # Include=c:\zabbix\zabbix_agent2.conf.d\*.conf
    ### Option:PluginTimeout
    #    Timeout for connections with external plugins.
    # Mandatory: no
    # Range: 1-30
    # Default: <Global timeout>
    # PluginTimeout=
    ### Option:PluginSocket
    #    Path to unix socket for external plugin communications.
    # Mandatory: no
    # Default:\\.\pipe\agent.plugin.sock
    # PluginSocket=
    ### Option: UnsafeUserParameters
    #    Allow all characters to be passed in arguments to user-defined parameters.
    #    The following characters are not allowed:
    #    Additionally, newline characters are not allowed.
    #    0 - do not allow
    #    1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    #    User-defined parameter to monitor. There can be several user-defined parameters.
    #    Format: UserParameter=<key>,<shell command>
    #    See 'zabbix_agentd' directory for examples.
    # Mandatory: no
    # Default:
    # UserParameter=
    ### Option: UserParameterDir
    #    Directory to execute UserParameter commands from. Only one entry is allowed.
    #    When executing UserParameter commands the agent will change the working directory to the one
    #    specified in the UserParameterDir option.
    #    This way UserParameter commands can be specified using the relative ./ prefix.
    # Mandatory: no
    # Default:
    # UserParameterDir=
    ### Option: ControlSocket
    #    The control socket, used to send runtime commands with '-R' option.
    # Mandatory: no
    # Default:
    # ControlSocket=
    ControlSocket=\\.\pipe\agent.sock
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    #    How the agent should connect to server or proxy. Used for active checks.
    #    Only one value can be specified:
    #        unencrypted - connect without encryption
    #        psk         - connect using TLS and a pre-shared key
    #        cert        - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    # TLSConnect=unencrypted
    ### Option: TLSAccept
    #    What incoming connections to accept.
    #    Multiple values can be specified, separated by comma:
    #        unencrypted - accept connections without encryption
    #        psk         - accept connections secured with TLS and a pre-shared key
    #        cert        - accept connections secured with TLS and a certificate
    # Default:
    # TLSAccept=unencrypted
    ### Option: TLSCAFile
    #    Full pathname of a file containing the top-level CA(s) certificates for
    #    peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    #    Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    #        Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    #        Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    #    Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    #    Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ### Option: TLSPSKIdentity
    #    Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    ### Option: TLSPSKFile
    #    Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    ####### PLUGIN-SPECIFIC PARAMETERS #######
    ### Option: Plugins
    #    A plugin can have one or more plugin specific configuration parameters in format:
    #     Plugins.<PluginName>.<Parameter1>=<value1>
    #     Plugins.<PluginName>.<Parameter2>=<value2>
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Plugins.Log.MaxLinesPerSecond
    #    Maximum number of new lines the agent will send per second to Zabbix Server
    #    or Proxy processing 'log' and 'logrt' checks.
    #    The provided value will be overridden by the parameter 'maxlines',
    #    provided in 'log' or 'logrt' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # Plugins.Log.MaxLinesPerSecond=20
    ### Option: Plugins.WindowsEventlog.MaxLinesPerSecond
    #    or Proxy processing 'eventlog' checks.
    #    provided in 'eventlog' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # Plugins.WindowsEventlog.MaxLinesPerSecond=20
    ### Option: AllowKey
    #    Allow execution of item keys matching pattern.
    #    Multiple keys matching rules may be defined in combination with DenyKey.
    #    Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    #    Parameters are processed one by one according their appearance order.
    #    If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Mandatory: no
    ### Option: DenyKey
    #    Deny execution of items keys matching pattern.
    #    Multiple keys matching rules may be defined in combination with AllowKey.
    #       Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    # DenyKey=system.run[*]
    ### Option: Plugins.SystemRun.LogRemoteCommands
    #    Enable logging of executed shell commands as warnings.
    #    0 - disabled
    #    1 - enabled
    # Mandatory: no
    # Default:
    # Plugins.SystemRun.LogRemoteCommands=0
    ### Option: ForceActiveChecksOnStart
    #    Perform active checks immediately after restart for first received configuration.
    #    Also available as per plugin configuration, example: Plugins.Uptime.System.ForceActiveChecksOnStart=1
    # Mandatory: no
    # Range: 0-1
    # Default:
    # ForceActiveChecksOnStart=0
    # Include configuration files for plugins
    Include=.\zabbix_agent2.d\plugins.d\*.conf
    Second config:
    ### Option: LogType
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Default:
    LogFile=C:\Program Files\Zabbix Agent 2\zabbix_agent2.log
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    #    3 - warnings
    # Mandatory: no
    # Range: 0-5
    # Default:
    DebugLevel=4
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: Server
    # Default:
    # Server=
    Server=xx.xx.xx.xx
    ListenPort=10050
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # StatusPort=
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=SiteBossServer
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Default:
    # HostMetadata=
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    # Mandatory: no
    # Default:
    # HostInterface=
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    # Mandatory: no
    # Range: 0-1
    # Default:
    # Mandatory: no
    # Range: 1m-365d
    # Default:
    # Mandatory: no
    # Default:
    ### Option: Alias
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: Include
    # Mandatory: no
    # Default:
    # Include=
    Include=C:\Program Files\Zabbix Agent 2\zabbix_agent2.d\
    # Mandatory: no
    # Range: 1-30
    # PluginTimeout=
    # Mandatory: no
    # PluginSocket=
    #    0 - do not allow
    #    1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # Mandatory: no
    # Default:
    # UserParameter=
    # Mandatory: no
    # Default:
    # UserParameterDir=
    # Mandatory: no
    # Default:
    # ControlSocket=
    # Default:
    # Default:
    # Mandatory: no
    # Default:
    # TLSCAFile=
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Default:
    # TLSCertFile=
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    ### Option: Plugins
    # Mandatory: no
    # Range:
    # Default:
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # Mandatory: no
    ### Option: DenyKey
    # Mandatory: no
    # Default:
    #    0 - disabled
    #    1 - enabled
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Range: 0-1
    # Default:
  • choiniere
    • Jul 2023
    Bumping for visibility
    • solution
      • Jun 2020
      • 272
      When it happens, check the Zabbix server and Zabbix agent logs.
      There may be some information that will help you in this case.​
      Wellington
