maintenance
  • mmbb123456
    • Jun 2023
    maintenance
    how do add 200 plus hosts in maintenance , I have the hosts in an excel file.
  • tim.mooney
    • Dec 2012
    • 1432
    If you can't use host groups to solve the problem, then I would look at writing a script or program that uses the Zabbix API to put all 200 hosts into maintenance.
    • mmbb123456
      • Jun 2023
      Hi Tim,
      is there a way , I can import the list directly via Zabbix UI , add it to a host group and them add that group under maintenance?
      • tim.mooney
        • Dec 2012
        • 1432
        Not that I'm aware of.
        • Vermizz
          • Oct 2022
          • 33
          This can be done via the API as Tim said.
          You can also mass add all these hosts to a given host group using mass update on filtered host.
          Do all these 200 hosts use a common template or do their names have the same prefix or suffix?​
          If yes go to the Configuration->hosts
          Next filter all needed host and use "Mass update" button and add all host to the host group. Next create maintenance for the host group.
          • Gatlinllon
            • Aug 2023
            Have you checked if the system you're using provides any built-in features, APIs, or automation tools specifically designed to handle bulk maintenance mode operations for a large number of hosts?
            • Cade324
              • Dec 2023
              What format do you want to export the host data in from the Excel file? (e.g., CSV, JSON, XML)​
