Haproxy http template with more instance
  • marypoppins
    • Jul 2023
    Dear All,
    I'm very noob in zabbix, so forgive me if my question silly. I have a machine with more haproxy instances what I should monitoring with the zabbix haproxy http tmplate. The instances have the stats page on the same ip but different port. In the template i have to set the port number, and I quickly realised that making more copies of the template with different port number is not to elegant solution, but I think that can be work.
    Is there any suggestion how to solve this problem with the correct way?
    Thank you very much
