Zabbix proxy discovered in old version, even if it's running 6.4.4
  • cnapan
    • Jun 2020
    • 12
    Hi Guys,
    Recently I have upgraded my master Zabbix server to 6.4.4, and did the same on Zabbix proxy server. Both hosted on Ubuntu 22.04 and both shows 6.4.4 after this command
    zabbix_server --version
    But, when entering on master zabbix to Administration - > Proxies, I can see my proxy is showed as 6.2.9 version still, with adnotation that " Proxy version is outdated, only data collection and remote execution is available with server version 6.4.4"
    ​What is going on? Why the proxy version in not being properly discovered?
  • Hamardaban
    • May 2019
    • 2714
    Probably on the proxy the command is different - "zabbix_proxy --version" .
    Have you restarted the proxy service after upgrade?
    Look in the proxy log and make sure that it is the new version that starts
    • cnapan
      • Jun 2020
      • 12
      You are correct. Zabbix proxy shows it is in 6.2.9. However, when doing upgrade procedure, I got information that zabbix proxy components are already in newest version. Somehow it refuse to upgrade to 6.4.4
