Can anybody help me? Unfortunately I can't figure it out, I've been looking for a while and tried different things.
I feel like I'm doing so well, but apparently not.
I would like to monitor the optical modules, but only see which ones are in it. so want to make a filter based on vendor or nu voltage.
For the voltage I did the following:
I have create a template, in this template create a item with snmp walk[oid,oid,oid,oid]
i create a discovery rule with a depended item and preprocessing: snmpwalk to json with: {#IFVOLTAGE} -> OIDprefix in this rule: .1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6
in this rule i have create a filter with:
A: {#IFVOLTAGE} matches {$IFVOLTAGE.MATCHES}
and
B: {#IFVOLTAGE} does not match {$IFVOLTAGE.NOT_MATCHES}
a macro in the template with:
{$IFVOLTAGE.MATCHES} ^.*$
{$IFVOLTAGE.NOT_MATCHES} -255 (also tryid ^.*-255$ and many more)
If i test this in https://regex101.com/ i have match the right rules.
But in my host i get the error: ".Cannot evaluate expression: "Cannot accurately apply filter: no value received for macro "{#IFVOLTAGE}".
Output of the snmp walk is:
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436622 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436686 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436750 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436814 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436878 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67436942 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437006 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437070 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437134 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437198 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437262 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437326 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437390 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437454 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437518 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437582 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437646 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437710 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437774 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437838 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437902 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67437966 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438030 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438094 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438158 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438222 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438286 = INTEGER: -255
.1.3.6.1.4.1.2011.5.25.31.1.1.3.1.6.67438350 = INTEGER: 3294
They host create the items, but all the items and not only with a module. can anybody help me? thanks
and
