Does Zabbix has default template for IPSLA monitoring?
  • netfar
    • Jul 2022
    I would like to monitor VOIP availability between a Cisco switch and Cisco Router, I would like to setup IPLSA in the Switch using ICMP-ECHO and monitor the delay, jitter and package loss. But I can not find the template in Zabbix 6
    Does anyone know where I can find the template? Thank you very much for your help .
    best regards
  • Aer0
    • Sep 2024
    • 26
    Hello!
    It's never too late)))
    I found all the necessary stuff regarding IPSLA for my Cisco by the following addresses:
    Zabbix com -> Integrations -> Cisco -> Available solutions -> 3rd party solutions -> VoIP IPSLA Discovery - if you want to monitor VoIP stuff
    Zabbix com -> Integrations -> Cisco -> Available solutions -> 3rd party solutions -> SNMP Cisco IP SLA - if you want to monitor channels stuff
    all of them are templates and all of them are working with Zabbix 7.
    In case of channel monitoring there is a key parameters there named "sense".
