Zabbix Top Hosts Not Showing All Data
  • tylerzeta
    • Jul 2023
    Hi all!
    I have set up Zabbix 6.0 and am using it to monitor many dozens of machines. They are all HP machines, so I found the iLO monitoring template someone posted here years ago. I modified the scripts and template to get only what I need, and it does work properly - I can see the data flow in. When I create a widget for "Top Hosts" on my dashboard, it does not show all the hosts with data. It only shows about 8 machines. I can go to a specific machine, check its Latest Data, and see that there is, in fact, data there that should be read by the Top Hosts widget but it's just not there. For example, the highest-ranking machine in the Top Hosts widget is about 450W of power consumption, but I can see the Latest Data for a different machine (which doesn't show up in the widget) has a usage of about 650W - I can see this with a single-item widget too. Unfortunately, I cannot take any images or screenshots to try to show what is going on...
    Any ideas?
    Thanks!!
  • tylerzeta
    • Jul 2023
    Hello! Anyone have any ideas about this? We updated to Zabbix 6.4 in the hopes it would help, but we're still having the same issue. Thanks!
      Without any config screenshots its kind of difficult... Have you set up properly, what column is for ordering the data? Are all the hosts included in selection?
