Vmware templates - to much login and logout by Zabbix
  • matib55
    • May 2023
    I'm using Zabbix ver.6.0.12 on CentOS 8.
    I'm using default VMware template to collect some data from ESXi and virtual machines.
    When I login to VMware system i see so much logs about login and logout Zabbix. I tried to change frequency of login for 1` hour in zabbix_server.conf file. Unfortunately this change minimum frequency of collecting data from VMware templates (for example i had item that collect CPU usage every 5 min., but now it collect only every 1h).
    So, i need that zabbix don't login and logout every minutes, because this will generate to much logs, and not change frequency of collecting data. It is possible to make this in Zabbix or in another way ?
    Best option for me it will be if Zabbix only loggin in and don't logout from VMware system. Eventualy logout every day.
  • matib55
    • May 2023
    No one can help ? Or have same problem ?
