Connection Zabbix to MSSQL
  • PiotrJ
    • May 2023
    • 26
    Hi
    I'd like to do a table on my dashboard where i can see which backup (job) failed.
    Database is on virtual machine in the same network with zabbix and its on MSSQL.
    Zabbix is on another virtualmachine with debian and its by the docker compose.
    Now i want cojnect database with zabbix and pull from the data base information about job (making backup) and placed it on the dashboard.
    Please help
    Im sorry for my weak engish.
    Regards
  • SanMonitor
    • Aug 2022
    • 49
    Hello Piotrj,
    we monitor our MSSQL using this template: https://www.zabbix.com/integrations/mssql
    Read the setup carefully, you have to create a user on your database with read rights & you have to install the Microsoft ODBC Driver on your Zabbix server.
    It monitors a lot, including jobs and last backup.
    • PiotrJ
      • May 2023
      • 26
      I followed the steps in order but I can't connect to the database that is on another computer in the same network. Don't I have to enter the IP address of the computer with the database somewhere?
        • 4993
        That probably should be in your ODBC config...
        • PiotrJ
          • May 2023
          • 26
          That means I can't connect without editing odbc.ini?
            • 4993
            If you don't want to edit all the items... yes..
            Please consult docs... https://www.zabbix.com/documentation...abbix-frontend
            • PiotrJ
              • May 2023
              • 26
              I have to up my zabbix on another virtual machine and my zabbix server is not avaible.
              please help.
