zabbix message about Cisco Switch
  • inomata
    • Dec 2022
    I have question about following zabbix message.
    ■zabbix massage
    High signal ALARM for TenGigabitEthernet1/1/30 Receive Power Sensor
    I have the following zabbix message from a specific interface of a Cisco switch, but I don't know the cause. Please let me know the cause and solution.​
  • Vermizz
    • Oct 2022
    • 33
    run comand: sh int te 1/1/30 transceiver detail
    Check what dbm you have on interface in value: Optical Receive Power
    Propably you need to go through the path and clean your connectors or replace transceiver module. You can also try replace FC cable to new one.
    • inomata
      • Dec 2022
      Hi, Vermizz-san,
      Thank you for your reply.
      I check dbm about int te 1/1/30.
      but look like this interface dbm status is normal.
      Could you check below image?
