Monitoring SSH (TCP 22 port) not working
  • Sajgon107
    • Mar 2023
    • 9
    Hello guys, Im having troubles with configuring a item to monitor SSH service on few devices. SSH servis (TCP22) service is running and i can connect from zabbix server over ssh to machine but zabbix still alerts ssh service down. I've used SSH template and as well custom item set as a simple check (net.tcp.service[tcp,,Port_number]) but I still got 0 as a return value. Could you help me out please?
  • Answer selected by Sajgon107 at 04-08-2023, 11:37.
    cyber
    • 4961
    If you want to determine whether zabbix can connect to all TCP ports, you must turn on the zabbix_can_network boolean. Disabled by default.
    setsebool -P zabbix_can_network 1
    • SanMonitor
      • Aug 2022
      • 49
      Hey Sajgon,
      any reason why you're not using net.tcp.service[ssh,,port_number] as your check?
      • Sajgon107
        • Mar 2023
        • 9
        Originally posted by SanMonitor
        Hey Sajgon,
        yes I did try that, still zabbix returns 0 value.
        • Vermizz
          • Oct 2022
          • 33
          can you try using like this: net.tcp.service[ssh] as a simple check
          Does the check work on others​ hosts?
          What system are you using on​ Zabbix Server? Maybe selinux (redhat/centos) or apparmor (ubuntu/debian) block simple check on SSH.
          • Sajgon107
            • Mar 2023
            • 9
            Hello, I've tried net.tcp.service[ssh] as a simple check but still Im getting 0 in return. Im running zabbix version 6 on centos distribution, when I try to connect from CLI of that linux machine to host over ssh the connection is working, this problem occurs on different hosts as well.
            • Vermizz
              • Oct 2022
              • 33
              For test only please check selinux is enable "getenforce" if yes disable it for test: "setenforce 0" and execute simple check.
              You can also run test like this: Login to Zabbix server and run command: zabbix_get -s 1.1.1.1 -k net.tcp.service[ssh]
              Where 1.1.1.1 is your destination hosts.​
              • Sajgon107
                • Mar 2023
                • 9
                Thanks for help, after turning off getenforce it worked. Can you suggest me how to configure it while keeping getenforce on?
                  • 4961
                  • Sajgon107
                    • Mar 2023
                    • 9
                    Thanks a lot, its working now.
