API request error using Azure HTTP
  • Modestinjs
    • Aug 2023
    Hello Zabbix forum,
    Wanted to ask you guys for some help regarding an issue i have setting up new hosts using the Azure by HTTP method mentioned in https://www.zabbix.com/integrations/azure
    Im using a VM that has been created in Azure
    After i have created a new host and put all the respective info in the Macros i get the following problem. "Zabbix has received errors in response to API requests.​" Ive not found any information regarding this error in the forums.
    Has anyone else come across this issue before?
    Thank you in advance.Click image for larger version
