SNMP Trap notifications
  • jcrowe-idgroup
    • Aug 2023
    I'm currently using Zabbix version 3.4.15 on CentOS 7. I inherited this server, and will be migrating to an LTS Ubuntu in the near future.
    For now, I need to receive email notifications for SNMP Traps received in Zabbix for a particular host. The host is an iDRAC 9 interface. SNMP traps are currently being received as viewable from Monitoring > Latest Data.
    My next issue is the configuration of the Trap under the Item I created for this. My expression in the trap is: {Saladfingers - idrac:snmptrap.fallback.last()}=1
    The expression seems to be sufficient enough for the expression constructor test, but the trap itself has an error. The error message is listed below:
    What would be the cause of this or what could be missing in my expression? I removed the IP, host, and domain names from a couple of fields in the message.
    Cannot evaluate expression: expected closing parenthesis at ":20:05 2023/08/04 PDU INFO:
    notificationtype TRAP
    version 1
    receivedfrom UDP: [x.x.x.x]:46142->[x.x.x.x]:162
    errorstatus 0
    messageid 0
    community public
    transactionid 28
    errorindex 0
    requestid 2110047442
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (60992763) 7 days, 1:25:27.63
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.674.10892.5.3.2.5.0.10395
    SNMPv2-SMI::enterprises.674.10892.5.3.1.1.0 type=4 value=STRING: "TST001"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.2.0 type=4 value=STRING: "The iDRAC generated a test trap event in response to a user request."
    SNMPv2-SMI::enterprises.674.10892.5.3.1.3.0 type=2 value=INTEGER: 3
    SNMPv2-SMI::enterprises.674.10892.5.3.1.4.0 type=4 value=STRING: "4RYG5S3"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.5.0 type=4 value=STRING: "[host.domainname]"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.6.0 type=4 value=""
    SNMPv2-SMI::enterprises.674.10892.5.3.1.7.0 type=4 value=STRING: "N/A"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.8.0 type=4 value=""
    SNMPv2-SMI::enterprises.674.10892.5.3.1.9.0 type=4 value=STRING: "4RYG5S3"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.10.0 type=4 value=STRING: "Main System Chassis"
    SNMPv2-SMI::enterprises.674.10892.5.3.1.11.0 type=4 value=STRING: "[host.domainname]")=1". zz0.is5h4aeuxhazz
  • tim.mooney
    • Dec 2012
    • 1436
    snmptrapd accepts the trap, calls a script or tool to write it to an intermediary file, and Zabbix reads that file and ingests it as a trap. What script or tool are you using to write the trap to the file that Zabbix reads?​
    It looks like there's a portion of the trap that is not being displayed, because it's part of the error:
    Right after that 2nd instance of "[host.domainname]", I think there's something additional that's being written to the trap file, that's not showing up here. Can you investigate the intermediate file and see if there is more that's not being displayed?
    If my guess is correct, that ")=1" and the remaining bit is the part after the chunk with the expression error.
