Change ControlSocket path
  • Sever
    • Aug 2023
    Do you know any specific requirements to change the `ControlSocket` path?
    vyos@r14# cat /run/zabbix/zabbix-agent2.conf
    PidFile=/run/zabbix/zabbix_agent2.pid
    LogFile=/var/log/zabbix/zabbix_agent2.log
    ControlSocket=/run/zabbix/agent.sock
    It is trying to use the old path.```
    vyos@r14# sudo zabbix_agent2 -R help
    2023/08/09 11:51:21.850087 Cannot send remote command: dial unix /tmp/agent.sock: connect: no such file or directory
    [edit]
    vyos@r14#
    vyos@r14# ls -la /run/zabbix/
    total 8
    drwxr-xr-x 2 zabbix zabbix 100 Aug 9 11:23 .
    drwxr-xr-x 41 root root 1240 Aug 9 11:15 ..
    srwx------ 1 zabbix zabbix 0 Aug 9 11:23 agent.sock
    -rw-r--r-- 1 root root 621 Aug 9 11:23 zabbix-agent2.conf
    -rw-r--r-- 1 zabbix zabbix 4 Aug 9 11:23 zabbix_agent2.pid
    [edit]
    vyos@r14#
