False positives on web scenario checks
  • kf4zmt
    • Aug 2023
    I am using web scenarios to monitor a website. It's working fine, but I get too many false positives. I need a way for the trigger to delay alerts until it has failed more than one check. My current trigger is:
    last(/Zabbix server/web.test.fail[mywebsite.com])<>0
    I have found older forum posts discussing this very issue, but the ones I could find were for older versions of Zabbix and my Zabbix version (6.0.20) doesn't seem to like any of the older solutions. I'm kinda new to Zabbix and I'm at a loss. I have found nothing in the documentation that seems to fit this situation. Any ideas?
  • kf4zmt
    • Aug 2023
    Can't be done? No one knows how?
    • markfree
      • Apr 2019
      • 875
      Check out the Web Monitoring Items
        Instead of last use some other method... for example min()
        your expression might look like this... min(/Zabbix server/web.test.fail[mywebsite.com]​,#3)>0 lowest value during last 3 checks is more than 0, which should mean, that at least 3 consecutive checks failed
        Its all there in docs.. https://www.zabbix.com/documentation...ions/aggregate
        • LenR
          • Sep 2009
          • 1011
          Something like min(/Zabbix server/web.test.fail[mywebsite.com],#2)>0​
