Variable in filename
  • JackOs
    • Jul 2016
    New user Zabbix, I can not build my test on a file that contains a variable in the name.
    Let me explain, I must make a check in a directory on the last file that begins with Mon_fichier_Test* -*.xml (example: Mon_fichier_Test-20160720-124117.xml
    If this file is more than 40 mins, I create an alert.
    I can perform well in my test file defines hard:
    vfs.file.time [app /../../Mon_fichier_Test-20160720-124117.xml ,change]
    But when I try to do my test taking into account the variable:
    vfs.file.time [app /../../Mon_fichier_Test-*.xml,change]
    I get an error message: No such file or directory .
    Using the following command , although I seem to get the last file that begins with Mon_fichier_Test*-*.xml
    ls -t Mon_fichier_Test * | head -1
    Someone can help me ?
    Thanking you in advance for your help .
    Regards,
