Installation/Setup problems
  • hellslide
    • Aug 2023
    Hello everyone,
    Today I wanted to install Zabbix on a Raspberry Pi, and have been following this guide:
    https://www.zabbix.com/download?zabb...ysql&ws=apache
    But it seems to me that the guide is not working correctly.
    I first got an error when I ran this command:
    HTML Code:
    zcat /usr/share/zabbix-sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix -p zabbix
    Should this really be in the utf8mb4 character-set, why not just utf8?
    I have followed the rest of the guide, until I finally came to configuring the rest of the frontend, until I ran into the following error:
    Cannot connect to the database.
    HTML Code:
      	Access denied for user 'zabbix'@'localhost' (using password: NO)
    I also become the error (using password: YES) when I do set a password in the config /etc/zabbix/zabbix_server.conf
    Any idea how I could resolve this issue? I spent the entire afternoon searching for a solution or even understanding the problem that's causing it.
    I suppose it has something to do with the wrong permissions?!
    Any help is greatly appreciated.
  • mihailo74
    • Jan 2024
    I've got the same problems, anyone out there that can help?
    • azyla
      • Feb 2024
      • 20
      Yes, it looks like the issue is caused either by password mismatch or lack of privileges.
      During the initial setup of database, did you change the 'password' part of below line?
      mysql> create user zabbix@localhost identified by 'password';
      If yes, make sure the same password is set as a value for DBPassword in /etc/zabbix/zabbix_server.conf
      If not, value of the configuration should be just the password instead.
      Also this line is important during the setup to grant newly created user all necessary privileges:
      mysql> grant all privileges on zabbix.* to zabbix@localhost;
      Last thing that comes to my mind would be restarting zabbix processes to make sure all configurations get loaded properly:
      systemctl restart zabbix-server zabbix-agent apache2
      Hope it helps.
      Regards,
      Arkadiusz
