Sensitivity adjustments
  • pryles
    • Aug 2023
    Is it possible to adjust the sensitivity of an alert? I'd like to be able to reboot a server but not get a notification until its been down for 5 minutes. Is that possible?
    It depends on your trigger config. You can modify it to react only after several consecutive failures...
    Just guessing here... currently it is based on last() function? You probably have to redefine it to use min() or max() or avg() with a time definition (5m)
