Exclude VM's with a tag in Proxmox
  • cgl
    • Aug 2023
    Hi all,
    I'm using the Proxmox VE by HTTP template for our Zabbix 6.4 setup with no issues.
    How ever, i would like to be able to exclude some VM's in Proxmox from a specific trigger,
    Proxmox: VM [{#NODE.NAME}/{#QEMU.NAME} ({#QEMU.ID})]: Not running
    So lets say VM "A" has a tag called "nozabbix", it wont have the above trigger added to it, since its making a lot of noise in our dashboards to have several problems for VMs that isnt running, that is turned off manually.
    Closing the problem in Zabbix, will have the problem come back every night.
    Any one done something similar?
    Regards,
  • X4V1
    • Mar 2024
    • 9
    Did you manage to do it? I'm also looking for a solution
      You should look for overrides. https://www.zabbix.com/documentation...overy#override
      • rkollman
        • Sep 2023
        Does somebody already managed to do this with the standard Proxmox VE template?
        If so, which steps did you execute to filter some VM's which are allowed "not running"?
