monitoring specific port traffic
  • asd01248967
    • Dec 2015
    Hello! everyone
    First apologized for poor english that express not clear-cut
    Q1.Have anyone know monitoring specific port traffic by item key(in、out、sum)
    I research Zabbix documentation>Configuration>Items>Item types>Zabbix agent & Windows-specific item keys
    but,I don't seem any could accomplish target for item key
    Q2.Or have other project can accomplish this requirement
    e.q:make a scripts by self and to co-operate User parameters
    hinet:I don't have any program experience
    thanks you very mych!!ALL!!
  • asd01248967
    • Dec 2015
    Please...Help
    Hello...
    Can someone tell me any answer or hint?
    or gave a URL ,than i could study myself
    • LenR
      • Sep 2009
      • 1010
      What do you mean by port? Like traffic for port 80 or 443?
      • asd01248967
        • Dec 2015
        thanks you reply
        yes!
        that's is my target
        have any idea can share with me?
        thank you!
        • LenR
          • Sep 2009
          • 1010
          Ok, how would you get this statistic from the command line? I briefly researched this, but I don't know if this is a good answer, this poster did it with iptables:
          http://unix.stackexchange.com/questi...r-network-port
          Once you can get the traffic counted, then you need a way to extract it. I think some form of iptables -L -vn | grep | cut could get you a single line with the desired port's byte or packet count.
          Now you feed that to Zabbix via a user parameter or zabbix_sender, if your value is total, set the zabbix item to store delta/sec
          This is a standard thought process of extending monitoring to items not built into zabbix and/or the OS.
          • LenR
            • Sep 2009
            • 1010
            Be aware that placement and other iptables rules can effect rules that are just for accounting. It's been awhile since I went this deep into iptables, but I think you would want those accounting rules after any rules that would drop traffic to these ports but before any rule allowing "established,related" traffic.
            For example, count of dropped packets & bytes from a blocked address range to port 10051
            iptables -L -vnx | grep 10051 | grep DROP | grep 10.133.9
            142385 8543100 DROP tcp -- * * 10.133.9.0/24 0.0.0.0/0 tcp dpt:10051
            • asd01248967
              • Dec 2015
              I understand what you mean and method
              but...needed feasibility method is for Windows Server 2008 R2 or Windows Server 2012 R2
              I research on Internet and then wasn't find can to do monitoring Windows specific port traffic(in & out)
              Please forgive me for express not clear-cut
              thanks
              • troffasky
                • Jul 2008
                • 634
                If such statistics are collected by the OS [and I'm not optimistic that they are] they may be available with WMI?
                If the OS doesn't collect them, the application may do.
                You may be able to try the iptables-style approach on Windows - create allow rules for the traffic you're interested in [if you don't have them already] and see if you can get stats from Windows firewall.
                Finally, tshark has statistics options - you could run tshark in a loop, dumping statistics once a minute [and discarding the capture].
                • asd01248967
                  • Dec 2015
                  WOW~!!
                  Thanks you very much your advice
                  I will learn how to using tshark function
