Macro for host PSK, or another way to define a PSK for reuse?
  • mko7
    • Aug 2023
    We want to enable agent encryption on a lot of hosts using a standard PSK and store the PSK once rather than having to enter/update it on every host. Trying to use a global macro in the host PSK field gives this error:
    Incorrect value for field "tls_psk": an even number of hexadecimal characters is expected.
    Is there another way to define a PSK that can be reused in the PSK field for many hosts?
    Thanks in advance (and for Zabbix!).​
    Zabbix 6.4.5
    No need to insert it by hand...
