Have several items extracted from one bitfield
  • ssl
    • Dec 2022
    Is there a convenient way to extract several flag values as items out of a bitfield? I've got a byte value retrieved over Modbus that contains status flags that I'd like to have as individual items with their own value mappings. I guess I can do masking of the value using preprocessing across several items (I'm actually not sure if this is possible, looking at the list of preprocessing operations, but I expect it probably is somehow) but due to the way the Modbus support in Zabbix works this will trigger 8 separate network retrievals of the same base value. Is there a better way to do this, e.g. some way to have the "base" item retrieved once, temporarily, and then several real item values derived from various fields of this base item?
    its called dependent items. You pull data once and then "attach" several dependent items to it and parse out needed value with preprocessing in dependent item.
    • ssl
      • Dec 2022
      Aha that sounds perfect - thanks a lot, I'll look at the docs for that!
