How to export the Dashboard from Zabbix?
  • vijayk
    • May 2023
    • 305
    Is there any way to export the dashboard from Zabbix? My version is 6.4.5.
  • Answer selected by vijayk at 26-08-2023, 05:45.
    vijayk
    • May 2023
    • 305
    Yes, I have configured the Grafana for better visualization and I'm also able to export the data from it. Now no need to do anything with Zabbix.
    Thanks you all.
    • gofree
      • Dec 2017
      • 400
      • vijayk
        • May 2023
        • 305
        How to export the Dashboard?
        • markfree
          • Apr 2019
          • 875
          Do you mean Scheduled Reports or just print the Dashboard?
          • vijayk
            • May 2023
            • 305
            I want to take backup of existing dashboard and import it in new zabbix server.
            • derli1988
              • Apr 2021
              • 60
              You list the tables of the zabbix database.
              You'd see these:
              | dashboard |
              | dashboard_page |
              | dashboard_user |
              | dashboard_usrgrp |
              maybe doing a mysqldump and then importing then to your new database server, you might be good to go.
              • Sebastian3234
                • Aug 2023
                How does Zabbix handle exporting dashboards that contain dynamic data or real-time graphs?
                • markfree
                  • Apr 2019
                  • 875
                  As suggested by gofree, you could try to use the API to manage a dashboard.
                  Even if your new server had the same hosts and items, they would probably have different IDs. So, if you were to export your dashboard (just the dashboard) to another server, I think you would have to reconfigure all the dashboard items again.
                  If your hosts have classic graphs already configured, that could make things easier.
                  Also, templates can have Dashboards models.
                  • vijayk
                    • May 2023
                    • 305
                    Thanks you all.
