Zabbix 6.0 upgrade - PostgreSQL history primary keys when using partitions
  • Arne Henrik Segtnan
    • Jan 2022
    Hi everyone,
    We have a Zabbix environment currently running version 5.0. Database in current version: PostgreSQL 12.0.
    The Zabbix dev-env has been successfully upgraded to 6.0. Database in Zabbix 6.0: PostgreSQL 15.0.
    Database has been set up with history and trend partitioning using Zabbix script 'partition_setup.sql'. We now would like to implement primary key for history tables in the upgraded version, as recommended by Zabbix. However, procedure for this task seems to have been created for non-partitioned systems only?
    https://www.zabbix.com/documentation...b_primary_keys
    'Important notes' states: If the database uses partitions, contact the DB administrator or Zabbix support team for help.
    What would be the recommended procedure for this task, when using partitions?
    From the Zabbix DB:
    SELECT relname, relpages FROM pg_class ORDER BY relpages DESC limit 40;
    relname | relpages
    events events_1
    events
    events_pkey
    event_recovery_2
    housekeeper
    event_recovery_pkey
    event_recovery_1
    items
    sessions_pkey
    event_recovery
    sessions_1
    housekeeper_pkey
    trends_uint_p2023_02
    history_uint_p2023_08_17
    trends_uint_p2023_06
    trends_uint_p2023_01
    trends_uint_p2023_07
    history_uint_p2023_08_18
    history_uint_p2023_08_19
    alerts
    history_uint_p2023_08_20
    history_uint_p2023_08_16
    history_uint_p2023_08_17_1
    history_uint_p2023_08_15
    history_uint_p2023_08_19_1
    history_uint_p2023_08_18_1
    history_uint_p2023_08_20_1
    history_uint_p2023_08_16_1
    trends_uint_p2023_08
    trends_uint_p2023_05
    trends_uint_p2023_02_1
    history_uint_p2023_08_10
    history_uint_p2023_08_15_1
    history_uint_p2023_08_08
    trends_uint_p2023_01_1
    history_uint_p2023_08_09
    trends_uint_p2023_06_1
    history_uint_p2023_08_12
    history_uint_p2023_08_13
    (40 rows)
    • 5008
    partition_setup.sql does not seem to be part of Zabbix installation... Something created locally? I guess that's why you need a DBA...
    For me partitioning PG instance is a new concept... I can see why it is done with mysql/mariadb (space usage and cleanup), but there is no such need for it in PG...
      • Jan 2022
      Thanks for the reply. This is probably something locally made by the previous admin in the company, as you say - inherited from our Zabbix 4.x (and now 5.x) setup, starting on PG 9. In our internal documentation, it is claimed that PG partitioning had significant positive impact on history table cleanup. Could that have been the case in older PG-versions, and that this is no longer relevant?
        • 5008
        Never used PG9. My old 4.4 was on 10.5+ timescale IIRC and I never had issues with cleanup... But it may aswell be the question of environment size... Currently running 14.5+timescale, same story.
        You don't seem to be using timescale?
          • Jan 2022
          Nope, we're not using timescale, probably something to consider to avoid the custom partitioning setup currently being used. Prod-env (PG 12) DB-size approx. 1.4TB.
            • 5008
            1.4T is pretty much, where I was... after enabling timescale compression also, DB size dropped to ~500G... And I don't see any perf issues.
              • Jan 2022
              Enabling timescale seems to be the right way to go, then - thanks a lot Just need to find out if it's possible to 'un-partition' the current PG database prior to timescale implementation, I suppose.​
