snmptt and zabbix updating
  • uvmvball
    • Jun 2016
    We've configured snmptt to send traps to Zabbix and that is working successfully.
    The issue is that when a varbind on the specific trap changes, a new snmptt/zabbix is not recognizing the change.
    The specific trap is cpqHe4FltTolPowerSupplyFailed from Compaq, and it has a varbind entry for varbind 5, cpqHeFltTolPowerSupplyStatus, which is an integer. snmptt/zabix will translate to text correctly (i.e. the instances from the MIB are as follows:
    noError(1)
    generalFailure(2)
    bistFailure(3)
    fanFailure(4)
    tempFailure(5)
    interlockOpen(6)
    epromFailed(7)
    vrefFailed(8)
    dacFailed(9)
    ramTestFailed(10)
    voltageChannelFailed(11)
    orringdiodeFailed(12)
    brownOut(13)
    giveupOnStartup(14)
    nvramInvalid(15)
    calibrationTableInvalid(16) )
    If I send a trap for, say, 'fanFailure(4),' I get the following in the snmptt.log file correctly:
    10:13:08 2016/07/25 cpqHe4FltTolPowerSupplyFailed CRITICAL "Status Events" 10.192.246.26 - Power Supply Failed (6050): The Power Supply is Failed on Chassis 23456, Bay 45678, Status fanFailure, Model model, Serial Num serialnum2, Firmware firmwarerev SparePartNum sparepartnum SystemID systemid
    and a trigger is created in Zabbix.
    But if I change the varbind to, say, 'generalFailure(2),' it just repeats the same output in the snmptt.log file:
    and nothing is written to Zabbix.
    How do I get it to recognize the new trap (since the varbind data has changed)?
    I have SNMP trap fallback set up in Zabbix as well.
    Trigger in Zabbix is:
    {Template SNMP traps:snmptrap["generalFailure|noError"].str(generalFailure)}=1
    The output to the snmptt debug file shows the entry w/ the same varbind as well:
    FORMAT line:
    I have an /etc/snmp/snmptt.conf.compaq file set up successfully (creates the initial alarm):
    EVENT cpqHe4FltTolPowerSupplyFailed .1.3.6.1.4.1.232.0.6050 "Status Events" CRITICAL
    FORMAT ZBXTRAP $aA Power Supply Failed (6050): The Power Supply is Failed on Chassis $3, Bay $4, Status $5, # Model $6, Serial Num $7, Firmware $9 SparePartNum $10 SystemID $11
    SDESC
    The fault tolerant power supply condition has been set
    to failed for the specified chassis and bay location.
    Variables:
    1: sysName
    2: cpqHoTrapFlags
    3: cpqHeFltTolPowerSupplyChassis
    4: cpqHeFltTolPowerSupplyBay
    5: cpqHeFltTolPowerSupplyStatus
    6: cpqHeFltTolPowerSupplyModel
    7: cpqHeFltTolPowerSupplySerialNumber
    8: cpqHeFltTolPowerSupplyAutoRev
    9: cpqHeFltTolPowerSupplyFirmwareRev
    10: cpqHeFltTolPowerSupplySparePartNum
    11: cpqSiServerSystemId
    EDESC
