hosts and dns : error gethostnyname()
  • dsipe
    • Oct 2006
    • 184
    hye,
    i create a host with its DNS alias instead if its @ip.
    when server start polling, i've got the message "gethostbyname() failed [ Unknown host] under the "Configuration -> Hosts" menu.
    Pinging the alias name on the zabbix's server work fine.
    What's wrong ??
  • markpr
    • Sep 2005
    • 31
    Try isolating this from zabbix and see if you can resolve DNS from some simple apache or php scripts.
    If I was to guess, based on the symptoms, you can't resolve DNS from apache because you have apache in a chroot jail without the libraries needed to resolve DNS.
    • dsipe
      • Oct 2006
      • 184
      i find the source of the problem: in the database, the length of the IP adress field is limited to 15 char.
      When creating my host, i try putting the all alias name [ serveur.eram.loc ] and this was truncated to serveur.eram.lo ...
      that was the reason.
      Can't this field by extend in future release ?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        serveur.eram.loc does'n sound like a IP address!
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • dsipe
          • Oct 2006
          • 184
          right, but searching in the forum, i found a post telling that to use the DNS name of a serveur, you need to put it in the @ip field.
          That's not correct ?
