How to monitor Multiple SQL instance, same Host?
  • chacaman
    • Aug 2023
    Hi team thanks for time and help, my question Can I make multiple full copies of the MSSQL By ODBC template to assign to the same host and monitor multiple SQL instances on the same host/server?
    Instead, create multiple hosts and assign same template to those. Any macros you need, define those on host level, not in template.
    • studero
      • Aug 2023
      • 85
      Hi Chacaman,
      I want also monitor multi instance of MS SQL. I want to know which Template do you have used ? And which type of user to made this monitoring ? AD User or user database ? With ODBC connect ?
      • vijayk
        • May 2023
        • 305
        Originally posted by studero
        Hi Chacaman,
        I'm using this template to monitor multiple instance. You have to create Macro for instance.
        • studero
          • Aug 2023
          • 85
          Thanks for the zip file. But I need help to use it ?
          Question: I'm not able to use an AD Service use. This is true ?
          • vijayk
            • May 2023
            • 305
            Yes, you have to create authentication user in Database.
            • studero
              • Aug 2023
              • 85
              Ok, I will ask my MS SQL DBA to create this user.
              But I need help to use your template without remove or upgrade the original ? How can do ?
              • vijayk
                • May 2023
                • 305
                You can rename the existing template and then import new one or vice versa.
                  Renaming a file (or a template in zabbix) does not do anything. Every entity in template has it's own UUID. To import same template twice (or more), you need to change those UUID-s (and template names/groups).
                  I don't think there is any big diff in official template (https://git.zabbix.com/projects/ZBX/...=release%2F6.4) or this one here attached above... they have same UUID-s, which means that their origin is the same.
                  If someone is providing a template to replace something available OOB, it would be nice to have a changelog.
                  • Ranjith.Rokkam
                    • Oct 2023
                    • 14
                    Hi Team - Greetings!
                    I need your help in montiroing the Named instances level monitroing in MS SQL through templates.
                    MS SQL services are running under named instance and MS SQL services need to be in monitoring.
                    Please help me on this.
                    Regards,
                    Ranjith R
                    • vijayk
                      • May 2023
                      • 305
                      You can follow the instruction from https://www.zabbix.com/integrations/mssql
