Zabbix SNMP how to delay trigger
  • tty
    • Aug 2023
    Good afternoon.
    At the moment, we receive notifications about running out of toner in the cartridge from Zabbix. Zabbix collects toner volume information via SNMP. Everything works, but there is a problem that sometimes SNMP on the printer gives a false value (0) for a while and the trigger fires accordingly on Zabbix.
    The current implementation is
    100*last(/Template SNMP Kyocera/.1.3.6.1.2.1.43.11.1.1.9.1.3)/last(/Template SNMP Kyocera/.1.3.6.1.2.1.43.11.1.1.8.1.3)<=10
    I want the trigger to only fire if the toner is <=10 for 30 minutes. So I can get rid of false positives.
    Tried doing this but it doesn't work
    max(100*last(/Template SNMP Kyocera/.1.3.6.1.2.1.43.11.1.1.9.1.3)/last(/Template SNMP Kyocera/.1.3.6.1.2.1.43.11.1.1.8.1.3), 30m)<=10
    Thanks in advance for help!​
  • tty
    • Aug 2023
    I also want to add.
    I tried adding an item that calculates the amount of remaining toner
    ​and changing the trigger
    the trigger started to work, but the delay does not work. those. trigger fires instantly​​
    • Mitchpeter
      • Nov 2022
      There is an OID for hrPrinterDetectedErrorState at 1.3.6.1.2.1.25.3.5.1.2.
      Bit 0 (128) = low paper etc. If this shows no toner the printer has really run out (not just very low).
