client authentication: agent --> proxy
  • iwidjaya
    • Apr 2016
    • 16
    Can anyone share how to setup 'client-authentication' zabbix agent --> zabbix proxy ?
    What are the prerequisite for this effort?
    I'm currently using active-agent configuration.
  • iwidjaya
    • Apr 2016
    • 16
    Please ignore it.
    Got the steps from 3.0 manual.
    https://www.zabbix.com/documentation...certificates?s[]=client&s[]=authentication
    • Wescott569
      • Jul 2018
      1. Open the Administrator Utility window.
      2. Click Users/Groups in the left pane to open the list of defined groups and users.
      3. Right-click a user or group and select Sessions to open the Configured Sessions window.
      4. If you are configuring a new session, click the appropriate button. If you are changing a session, right-click the session icon and click Properties.
      5. In the left pane, click Connection.
      6. In the right pane, in the Protocol listbox, select a secure protocol (either Telnet-TLS or Telnet-SSL only).
      7. In the left pane, expand Connection and click TLS/SSL.
      8. To enable server authentication, select Server authentication. Read about known security limitations when using the Internet.
      9. To use client authentication, click Yes for sending a Certificate.
      10. Specify the Certificate Source and Certificate Location or Certificate Name
      • bettydiaz
        Banned
        • Oct 2018
        .1. In order to verify peer certificates, Zabbix server must have access to file with their top-level self-signed root CA certificates. For example, if we expect certificates from two independent root CAs, we can put their certificates into file /home/zabbix/zabbix_ca_file.
        2. Put Zabbix server certificate chain into the file, for example, /home/zabbix/zabbix_server.crt.
        3. Put Zabbix server private key into the file, for example, /home/zabbix/zabbix_server.key
        4.Edit TLS parameters in Zabbix server configuration file.
