Add variable to Tag name and value
  • Inewthinker
    • May 2023
    Hi all,
    I am trying to change the ITEMS and TRIGGERS tag name an value with a variable that will add the host name and the Item/Trigger name - (example: Item.{#VM.NAME})
    I did it to the tags for the hosts in the TEMPLATES ( tag name: SERVER / Tag Value: {#VM.NAME} ), and this transferred the tag name and value to all the servers.
    Can I do it to the ITEMS and TRIGGERS as well?
    Hope I explain myself well
  • Inewthinker
    • May 2023
    anyone? Please
      • 4993
      You can use those LLD variables that are present in that discovery. If that discovery has item/trigger prototypes, then you should be able to add similar tags there also.
