SSH - Executed Script - JSON macro variable
  • jonathanmasse@hotmail.com
    • Aug 2023
    Hi all,
    I'm running Zabbix 6.4.6.
    I want to parse a JSON user macro.
    My variable $ROUTER.IP_LIST is under JSON format.
    I tried to use regsub or iregsub but It doesnt work.
    Is macro function is disabled in executed script?
    Basically, I want to parse the variable $ROUTER.IP_LIST before sending the value.
    Thanks,
