Graph widget - data is trimmed when hovering with the mouse
  • andreas777
    • Jul 2022
    • 16
    Hi there!
    I have a graph widget for ICMP loss.
    There are 28 hosts and for each host the ICMP loss value.
    When I am hovering with the mouse over the graph a pop-up shows me some more details, BUT not all hosts are shown. As you can see from my screenshot there is one host with ICMP loss higher than 20%, but in the pop-up, this host isn't shown. This is quite useless, sadly.
    Is this happening on purpose or is it a bug?
    If this is happening on purpose, is there a setting where I may adjust the number of displayed hosts?
    I really appreciate any help.
    Greetings
    Andreas​
  • jtnfoley
    • Mar 2022
    • 82
    Had to do the same thing for a different reason recently.
    Crediting the answer I found: https://www.zabbix.com/forum/zabbix-...nd-on-my-graph
    Edit /usr/share/zabbix/include/defines.inc.php
    Find and change the number of rows:
    // widget defaults
    define('ZBX_WIDGET_ROWS', 30);
    ​(I opted to set to 30 for my purposes. Default is 20.)
    • andreas777
      • Jul 2022
      • 16
      Hi jtnfoley!
      Thank you very much for the answer!
      The directory "zabbix" under /usr/share doesn't even exist at my zabbix-server. Is there maybe another location for this file or am I supposed to create the directories and the file?
      Greetings
      Andreas
      • jtnfoley
        • Mar 2022
        • 82
        On any UNIX/Linux:
        find / -name defines.inc.php -print
        • andreas777
          • Jul 2022
          • 16
          Aaaah I were in the false directory - forgot that it is a docker container. Of course I used "find" but in the false path.
          Thank you!
          • jtnfoley
            • Mar 2022
            • 82
            Ha! I'm quite a bit older than docker, I forgot that was an option.
