Need help on SPECIAL https web monitoring
  • ora
    • Jul 2016
    Dear all.
    I configured zabbix 2.4 on RH5.10, it works well, and could be used to monitor http web site, and get correct "required string", even on some https site, but it encountered problem on:
    https://login.partner.microsoftonline.cn/login.srf, for can't get "required string":
    1) the configure of authentication is like following:
    HTTP Authentication: none,
    SSL Verify Peer & Host: not checked,
    SSL Certificate File: none
    although I read several times of documents and try to use the certificate file created by openssl command, it seems useless, could you give me some advice on how to set authentication mode, and how to create SSL certificate file, in order I could get required string?
    2) I also want to simulate the login process, and the source code of input box of login.srf is in the attachment:
    I set following in the zabbix post box:
    [email protected]&cred_password_in puttext=abc@abc&enter=cred_sign_in_button
    I wonder that's correct? the strings need ""?
    To analyze more convenient, I also log_level_increase, and attach some part of the log.
    I worked on these questions several days, and really need your help or suggestions, thanks in advance.
    BR
    ora
  • ora
    • Jul 2016
    Need I post more info?
